- 23 Sep 2009
- London
Hi,
I'm looking for some simple fan filters for a 480mm rad and 2 240mm rads. They currently have rubber gasket/dampers which also act as shrouds between the fans and rad which are in push configuration.
I'm not sure if the magnetic DEMCiflex would be best, wouldn't it be better to get fan filters that stick on in front of the fans? The fans at least would still push static pressure without the filter restriction, although the air being drawn to the fans will be restricted due to the filter.
tl;dr I'm just looking for simple thin mesh filters that just screw in front of the fans rather than the ones with a thick shroud/bezel after the fans if that makes sense.
I saw a post on the forums here where someone used some round ones and did it this way but I can't find the link anymore
