As title really, how much an effect do filters have on the airflow from case fans?  Cut in half/third/quarter or whatever?
Got a couple of 80mm intakes but the inside of the case is getting too dusty so I'm thinking about putting filters on them. But concerned that would cut too much airlflow. The fans I've got are 19dB/21CFM only as it is, so can't really afford to cut that I imagine.....
I don't really want to have to get higher cfm fans, for noise reasons, just to keep the same airflow in the case.
