- 17 Apr 2009
- East Northants
Hi everybody.
Since i purchased my new case (HAF 922) and installed all of my fans along side the ones the ones that came with the case.
I now have a Xilence Red Wing 120mm as an exhaust fan at the back, a Red Wing 120 as an intake fan at the bottom of the case and an Enermax Cluster 120 on the heatsink.
This is along side 1x 200mm intake at the front and a
1x 200mm exhaust fan at the top.
Now, the front 200mm intake fan (that came as standard) has its own removable filter so there is no problem there. But the Red wing that i installed at the bottom of the case as an intake fan doesn't have a filter at the moment. I currently have that fan turned of so that the case doesn't fill up with dust.
So, after that long winded explation, my question is;
Can anyone recommend a 120mm fan filter that will fit onto a Xilence Red Wing 120mm that is installed using rubber grommets?
Thanks
Thanks
. My wife claim that her tights are really warm (whenever I complain that she may got cold). So I think it will not let any wind go through it.
