Fan fitting Help
27 Mar 2016
Bristolian living in Swindon
Hi all
As title says, I need some help with my fan setup... I have 2 thermaltake Riing fans to install into my case.. I'm feeling very silly at the moment as I've plugged them into what I can find but they both ended up in the same plug... what do I need to change or add
Sorry this is my first build on my own, last time I had help
http://imgur.com/9icAs1G
Thanks
That plug will connect to one of the PSU cables ( you'll usually have a cable with a couples of flatish 4 pin connectors on it.
Something like this :
