So I'm currently using a couple of Asaka Apache Black to cool my radiators, but I was wondering if there was anything better? I've had them for over 5 years and no idea if I should replace them. Noise is not really that much of an issue.
.If it's not broken don't fix it. Your happy with noise and cooling?
. Noise is fine and so is cooling but I feel cooling could be a tad better.Cheers I'll have a look, although there seems to be different ones? Any specific model I should be looking at? OcUK's 3 fan bundles looks quite tempting.
I just felt like I need a change. Noise is fine and so is cooling but I feel cooling could be a tad better.
Thanks, received your trust message as well.
Although I just had a recheck on the static pressure/air flow on my Apaches vs the EK-Vardars, I didn't realise my Apaches were actually very good. Now that just puts me off from changing them.
Nothing fancy, just a Corsair H40 on the CPU and a H75 on the GPU. I plan to change the CPU cooler to something more beefy when I upgrade the CPU later on however.
.in my view AIO is a bit of a gimmick, there good for small cases but a good air cooler is a hell of a lot better than AIO
Better at what?
quieter, better cooling.
take a £60/£70 120mm AIO and put it up against a £60/£70 air cooler.
Quieter during idle maybe, not necessarily under load though.
Air cooler also has RAM clearance issue, tower height clearance issue, PCI-e slot clearance issue for SFF...
