Hi guys, was noise hunting in the PC the other day (thought i heard a strange rattle).
Held all the fans still for a second one by one to see if i could pin it down, held the graphics card fan still for a second or two without really thinking about it.
Do you think i have damaged the motor on the fan or will it most likely not be bothered?. Also i dont think having the fan off for a second wont damage the card will it? (in 2D mode on an 8800gts).
Re-assurance appreciated!
Cheers.
Cheers.
