Fan guard/grill for Silent Wings 140mm
There different mounts on the fan, but the hole spacing should be the same, so any 120/140 grill, guard should do the job
Your right the hole spacing IS the same but there is no where to screw the screws in when you use the mountings that require the screw on the other side, I have tried to take a few images to show you my point.
and
All1
