Hello all, just a quick question.
I'm just moving my PC into a new case, and have 2 60mm fans I'd like to speed control, so I'd like to run them both off the system fan header on the motherboard. My question is whether it'll damage the header / board by running 2 fans.
Each fan is rated at 0.17A at 12V, I've checked my motherboard manual (GigaByte Ga-K8NXP-9) but it doesn't say how much current you can pull from the fan headers. 0.34A isn't a lot so I'd guess it would be fine, but I was wondering if fan headers are really restricted to 1 fan.
Thanks,
Scott.
Thanks,
Scott.
