Fan heads up
I have a couple of the AK-FN059 on my rad, they work really well.
Similar specs, different blade design to these though.
I might grab a couple of these for a rainy day.
Bought 8....2 for my h80i and 6 for my H440..
Now I just need some way of controlling them...
I was thinking of a fan splitter but most only allow 5, I cant have 1 running full pelt.
I see, I shall be ordering then.
They all should run at the same speeds right?
5 fans via the splitter on one 4 pin motherboard header,
then 3 fans via another splitter on the 4 pin cpu header on the mobo?
IIRC martinsliquidlab tested these a while back, result was good fans, not as good as GT's, Noiseblockers or SP120's but still good, they're definitely a bargain at £5.
