Right, i'm in need of some advice. Just this morning I dusted out my whole pc. Now it's running my i3 OC at 4.2 at about 25 celcius idle.
It used to run 30+ This I obviously took as a good thing however the fans on my machine are loud. Not overpowering but id like to think I could get them a lot quieter. I have 2 x 120mm and 2 x 80mm also cpu and gpu fan. Im using a beasty Akasa nero cooler.
I was wondering if these 'silent fans' I keep seeing would reduce my noise. something like this:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-024-AK&groupid=701&catid=57&subcat=
Ive noted the decibel difference between my current fans and its about 7db. I was wondering if this would make a huge difference?
