fan help
2 Aug 2006
Liverpool
hi is the following fans ok for radiators
Akasa 140mm Viper
also what is a good 4-1 pwm fan adapter, 2-1 pwm fan adapter and a 3-1 pwm fan adapter
The Viper is a good fan as it has great static pressure which is a must for radiators.
As for the splitters, do you need four fans on one header or just two? they all do what it says on the tin :)
thanks so there good for the radiator and yes I need four fans on 1
3x 140mm radiator fans on the 3 way splitter
4x 140mm fans on the 4 way splitter
2x 120mm fans on the 2 way splitter
at the moment Thermalright - Archon IB-E X2 but its getting swapped for a alphacool eisbear 420, it's hitting the temps when mining with awesome miner
