- 10 Jun 2009
- Darlington
Hi guys.
A while back I took my Corsair ll120's out of my sons build and put them away in my storage box.
Ive gone to re use them today in my new build and I connected them all up and the fans spin perfectly but no rgb. They were connected to the hub correctly no issue there but when I investigated the rgb wire on fan 1 is damaged which has had a knock on effect.
Anyway long winded I know.
One wire has come out of the rgb header on the fan completly, is it an easy fix? Can it be done? Anyone with the tip to help me do it? It looks as though the wire pushes into the header but im assuming its maybe soldered in?
Any help, seems a shame to waste the fan.
Thanks
Thanks
