Fan = High temp???
4 Feb 2011
I've just finished installing another fan but for some reason when i went to test out my game on max settings I got readings of higher Temps on GPU and CPU than i did with out it??
Does running a game in windowed mode and full screen effect those results??
If your case air flow is bad, higher fan settings can result in hotter air being blown onto certain components increasing the temperature of them.
