Fan Information.
31 Dec 2011
Hi,
I need a little info regarding case fans. I recently got a Phantek Enthoo Pro which has a 200 at the front and a140 at the rear. I would like to fit 2 x 140's to the top of the case as I feel the two that are fitted plus the CPU fan may not be sufficient for cooling the system. Should the top fans push air in or pull it out. A very basic question I know, but I want to be sure I fit them correctly.
Thanks in advance.
Front and bottom should be intake, while back and top should be vents. Ideally you should have more air in than air out, as this will create positive pressure in the case to help keep the dust out (not every hole in the case has a dust filter over it).
