- 20 Aug 2012
Hi
Not sure where to ask this...
I am build a new system with a Gigabyte GA-Z87X-DH3 motherboard.
I have a front 230mm case fan on Sys-fan3, two 200mm fans on the top on Sys-fan2 and a single small one on the rear on Sys-fan1.
The fans that share a fan connector use splitters, but I am only using one of the white speed sense cables on each channel, other wise it seems to confuse the readings.
However - every fan, including the CPU fan (which is plugged in CPU-fan) are barely running. 250-500 RPM.
Nothing I do in either bios or the Gigabyte Easytune seems to make any difference to fan speed. In fact, since I asked it to calibrate the fans, they are running even slower.
Any ideas?
Thanks
Any ideas?
Thanks
