- 30 Mar 2023
- UK
My youngest lad has just informed me that his computer is making a strange noise, following a bit of investigation it seems that the fan at the back of his PC is rotating slowly and making a whirring noise - so I figure its on the way out.
As I have some spare fans I followed the cable back to the motherboard and was about to swap it out when I realised that the cable has an additional cable coming out of it that appears to be attached to another fan (if that makes sense). To put it another way, starting from the motherboard 2 cables come from the same fan header, 1 is directly wired into the fan, the other is a couple of inches long and has a connection that another fan cable is attached to.
Can someone recommend a good replacement fan? There are plenty on ***Elsewhere***/Overclockers etc but I don't really know what I'm looking for re. the cable and don't want to end up with another similar to the ones I already have (without the little extension bit)
Hope that makes sense!
Thanks.
Thanks.
