fan layout help for ThermalTake Core X31 TG
6 Nov 2006
Redcar
So i have just bought the ThermalTake Core X31 TG for a new build and was wondering what you all think would be the best fan layout?
I will be air cooling using a Noctua NH-D15s.
out of the box Cooling System: Front (intake): 140 x 140 x 25 mm Riing LED Blue fan (1400rpm, 28dBA) x 1 (1000rpm, 22dBA with LNC) / Rear (exhaust) :140 x 140 x 25 mm Riing LED Blue fan (1400rpm, 28dBA) x 1 (1000rpm, 22dBA with LNC) "A 140mm blue LED Ring radiator fan with high-static pressure design"
and the case can take the following configurations.
Fan Support: Front: 2 x 120mm , 2 x 140mm , 1 x 200mm / Top: 3 x 120mm , 3 x 140mm , 2 x 200mm / Rear: 1 x 120mm , 1 x 140mm / Bottom: 2 x 120mm , 2 x 140mm
So for air flow in the case would moving the front fan and getting a 200mm be better or would it be better to get an additional 2 140mm fans ?
