Hi.
Am running a Fractal R5 as a file server, 8 HDDs, so is getting rather toasty with the default:
1 x Fractal 140MM Gp14 at the Front (Pull IN)
1 x Fractal 140MM Gp14 at the rear (Push out)
Although a great case, cooling is not their forté but they do hold 8 HDD's so making the best of it
I need to add more fans.
I am going to add another to the front so 2 x GP14 140mm at the front (maximum).
If I add 2 or at the top pulling out (not filtered so would prefer to avoid dust intake), would that affect the cooling mojo if I had:
2 x 140MM FRONT (Side intake)
2 x 140MM TOP (Pushing out)
1 x 140MM REAR (Pushing out)
My thinking is the HDD's are getting that hot that the front fans are having little effect on system temps as by the time the air gets to the system having passed the HDD's, it is already too warm.
Thanks.
.I need to add more fans.
Thanks.
