- 1 Jan 2012
- Scottish Borders - UK
This is my case....
I currently have an intake fan (120mm rad in push pull) at the front and a 240 rad in the roof exhausting air.
My thoughts are this...
The air being brought into the case via the front fan will be warm due to passing through the rad. So the air getting pushed through the 240 rad in the roof will be warm air.
I'm not 100% sure if I can fit a rear fan inside the case due to the rad as I had to move the rad back a little to fit the recon fan controller in.
My options....
Leave as is and either have an exhaust fan at the rear - possible mounted externally.
Mount a rear fan as intake. Have the top rads exhausting and the front rad exhausting. This way all rads get the coolest air.
A portion of the rear fan will be blocked by the rad also.
Thoughts??......
My options....
Thoughts??......
