Fan Masacre....
27 Feb 2007
England, Plymouth
Guys what do you think? Claim or not? lol
If youve ever wondered how much power is in one of those little plastic fans, well here you go...
Cheers Shr3k
Cost of fan
£1.99
Cost of computer
£600
Best m8 LANGUAGE! himself, the loud bang, the lights cutting out and the mass panic.....
PRICELESS
other images 1
other images 2
other images 3
Hi,
First of all, i wouldn't agree its class... It could have eaten my pc :S
Secondly, well i think the fan dropped slightly off its sopindle and still spinning (with power) carried on into the case a bit then the mounts shattered and it ate its wiring. Causing the psu to trip and my home circuit breaker to also trip :S
It sounded scary.... Scraping, chewing then a bang.... In all it lasted about a second though....
My heart was still racing 10 minutes after!
LMAO
Shr3k
Man i thought you meant someone mowed down a bunch of Britney fans.
Maybe you overtightened it and it cracked the frame and broke it over time?
Hi,
QUOTE
if only mate!! i would pay to see that :D
The screws wern't over tightened. Ive fitted opver 20, yet i better go check them lol ;)
If you look you can actually see it was the fan supports that went not the fan casing?
But hey, LANGUAGE! happens lol
Shr3k
Thought me pc was ok,
but just checked me mobo doesn't seem to be functioning correctly :S
Gonna contact the place i bought them from, see what they say.
Shr3k
Looks like a cheapy fan . . . . . . . Im amazed the fins are still intact. Though it ate the cable quite nicely. Must have been hungry.
