Fan Mod
18 Oct 2011
Sorry if this is in the wrong section but i didnt know where to post it, its nothing that exciting but for me its my first mod to my pc =]. All i did was use some anti-static foam from a GPU box and cut a square out to fit it round my fan and then wedge it into the top front slot of my pc
Case is a Sharkoon T9 and i wanted a third fan in the top but there was no mounting bracket like the other two was using, so i had to make one myself. Seems to be ok so far no noise or anything like that, only difference i can see is it is slighty further back than my other fans
