Hi at the min I have the standard fans that came with my cooler master 922 plus the stock cooler that came with the i7 2700k. Thing is I want to replace the fans inside the case and the stock cooler to make my system run allot quieter as I do allot of my downloading at night and the current noise levels keep me awake, also with the cpu cooler I'm looking at something like Phanteks PH-TC14PE.
If you could please give me some advice on which are the best fans to buy and cooler that would be great. P.S My room is the hottest room in the house so I will need a good cooler and fans (while still being quiet) to keep temps down.
Thanks
Thanks
