I just recieved a pre built sytem from ocuk.
Titan 8700i Pulse.
Very happy with everything except that its a bit loud.
I'm thinking i should have gone with a more silent option as it is in my living room.
Anyhow, i was wondering what my best options are with regards to reducing the noise.
The fan speed control does not appear to be working from the BIOS options.
I assume this is because the fans use a 3-pin setup, so not PWM ?
I do not know much about this truth be told.
So, do i buy some sort of fan controller OR replace the current fans with something that can be adjusted ?
Advice very welcome here thanks for reading
______________________________
"Titan 8700i Pulse"
[email protected]
Asus P8Z77-V LX2
Corsair H60 Bulk Cooler
OcUK Tech Labs Zaward 120mm Golf Ball Fan
Titan 8700i Pulse.
"Titan 8700i Pulse"
[email protected]
Asus P8Z77-V LX2
