- 13 Nov 2009
I've just added another a second GTX 275 to my system for SLI.
This all works great but with one slight annoyance which is the fan noise.
If only 1 card is plugged in (and it doesn't matter which one), the fans will spin at 100% for about 10 seconds and then go to normal as the system is posting.
However, if both cards are plugged it, the fans continue to spin at 100% until Windows has loaded up the drivers at which point, presumably it's telling them to go back to normal.
Now this doesn't sound like too much of a problem, but I boot the system into other OS (Linux and OSX). This means that if booting into either of these systems, the fans are always stuck at 100%!
Is there a way to force these to just start up at a low fan speed and raise if needed like they do when plugged in independently?
