Finally managed to get round to opening and cleaning the inside of the PC. The excess fan noise seems to be coming from one of the 3 (2 are off) GPU fans right from start of PC with no apps running. Tried using "Fan Control" software to turn off the fans but the one running will not turn off. Increasing GPU speed turns all 3 on, so all are working. The GPU is Gigabyte Aorus GeForce GTX 1660 Gaming OC 6G (about 6 years old)..
To be sure, can I boot the PC without this card to make sure that it is the culprit? Is there any other way to test it?
This PC ism now used for day to day general use (no gaming). Can someone recommend a decent GPU replacement, if necessary, for up to £150-200 pounds?
