- 11 Feb 2022
- London
I need help with my set up, here are the specs
Lian li odynamic
Arctic freezer 360 mounted on top as exhaust
3 sl120 mounted on the side as intake
3 sl120 mounted at the bottom as intake
12700k
3080 ti FE
8x4 ballistix 3600 cl 16
Z690 edge wifi
850 rmx
So I use msi burner to undervolt my GPU it runs stable at 885MV at 1905. I set the fans curve manually with zero rpm override (fan should be at zero when GPU is below 40c) but it doesn’t get activated so it’s stuck at 1000RPM all day which is 30%
Then I use fancontrol and set my pump fan curve and my sl120 since they’re all connected to one lian li hub I can’t see the rpm but they use the same fan curve.
I experience strong vibrations and hum from the fans when gaming to keep the temps low. The sl120 are very loud at full speed and are the ones causing the problems. So I’m wondering if it’s because the liquid freezer and the sl120 have max rpms that cause these issues and how I can resolve this
Lian li odynamic
12700k
3080 ti FE
Z690 edge wifi
850 rmx
