My sisters fan on her laptop has stopped spinning after i used a hairdryer to get the load of crap from inside her laptop.
Anyhow, i think that by doing this that ive somehow stopped the fan from not spinning. Its much quieter than it was before, and in Everest, the CPU temp is at 82 degrees!
I've phoned up Toshiba (EA60 Equim) and they said go to a local shop and see what they say. I asked them what to do if that wouldnt work and they said they would take a look. Now as the laptop was second hand about a year ago, i dont think it will be under warranty as i bet it is at least two years old by now.
Would you go to a shop or would i get ripped off massively? Or would you phone up Toshiba and get them to have a look at it, even if it isnt under warranty. My biggest issue with the latter is that they could fix it but then send me a huge bill when i get it back that i wasnt aware of.
Thanks fellas.
Thanks fellas.
