Fan not working on R9 270x
13 Jul 2005
A friend of mine said hes been having problems with his graphics card he purchased used from a wifes friend, its been crashing a lot as well as blackscreening. So i installed it in my computer for him and it kept freezing after 10 minutes pretty badly during outlast to the point where it eventually froze and close the program. I had GPU temp showing at it seemed to happen when the gpu hit 53 degrees so i took a look and noticed one of his fans want working.
His graphics card is an Asus Radeon R9 270x direct cu ii top and upon booting it seems the fan functions fine but at some point during games loading it stops for some unknown reason.
Is anyone familiar with this problem with these cards, id assume its a bad fan or something so what are his options ? because apparently getting his money back from the guy isnt one. I suggested maybe a gpu cooler or something or replacing the fan ?
