Hello,
I am using the Coolermaster Elite 335 Case with a front 120mm fan bringing air in and another 120mm at the rear drawing the air out. I noticed on the side panel there is a little grill and also what looks like a plastic tunnel attached? I basically just wanna know if I could remove that tunnel and put another fan there to target the CPU with more cool air? the hole seems to be about 80mm but I'd like another 120mm fan there and was wondering if there was something that would let me do that without sawing through the case.
Thanks
Thanks
