Is there not a 'hybrid fan mode' switch ? It should be next to the on/off rocker switch on the back of the psu. If you put it on hybrid mode, then it shouldn't spin until it reaches a certain load.
I have the 1000 watt platinum, and i've only ever seen the fan on when mining, i think it comes on at 45 degrees as said above, depending on what position the switch is on.
