- 6 Nov 2005
- Newcastle,UK
Hi
I'm looking to pick up some Phanteks D30 120mm DRGB PWM fans, 10 to be precise
3 top exhaust
1 rear exhaust
3 bottom intake (reversed)
3 on the rad
Question is, do I go normal or reversed on the rad??
Logic says normal but then it's just pulling hot air from inside the case over the radiator but if I go with reversed it's then got to pull 'through' the radiator.
What are people's thoughts?
Cheers
3 top exhaust
1 rear exhaust
3 on the rad
Cheers
