Hi guys/gals,
got a new 120mm case fan today and thinking of installing it on my case.
I`m running about 44 deg c on idel at standard on an e6600 with my arctic.
I currently have a 120mm exhaust fan under the psu, the psu fan exhausting, and an 80mm intake fan at the front with a hardrive stuck behind it.
i`ve just bought a new 120mm fan today, so would you recomend swapping out the small 80mm one at the front and replacing with this 120mm one?
I could then use the small 80mm one at the bottom at the rear to exhaust some of the warm 8800gtx deg air that it bellowing out.
Was also thinking moving the h/d out of the way of the primary airflow a bit.
You think this will improve the temps?
Cheers, ollie
Cheers, ollie
