I've finally finished* my new build, but I didn't really have a strategy when I started so it's a bit of Frankenstein, and I'm not sure about my fan placement. As far as I can tell as long as air is moving you're pretty much good, and the CPU and GPU are water cooled so I'm probably fine anyway, but I'm still having a lot of debates with myself.
My case (Thermaltake View 27) has five fan mounting points -- one top-rear, three at the front, and one at the bottom -- and currently I have the radiator for my MSI Seahawk X venting to the rear, a Corsair H45 radiator venting through top-front, and then two beQuiet fans mounted as intakes below that (one running at constant full speed, the other controlled by motherboard temp).
Temps are good, but the thing that bugs me is that there's no consistent direction of airflow -- I'm so used to the "in at the front, out at the back" deal that it just doesn't feel right not having air flowing through the case in one direction, and part of me wants to mount the two radiators at the front, put an intake at top-rear, and have the third fan at the front as an exhaust -- that way air will just flow from back to front and I'll have more exhaust than intake pressure to keep the pesky dust at bay.
(...and this is why I gave up building PCs 15 years ago.)
* Still mucking about with lighting, I may replace the PSU with a modular one so I can use prettier cables, etc., but all the expensive bits are done!
