Fan placement help please.
18 Mar 2012
Eastbourne
I would just like to check that i'm getting the maximum cooling efficiency from my case.
I have two Corsair SP120 Low Noise fans at the top and the rest are just the ones that come with the case.
Any help and advice would be great
Your prob creating neagative pressure in the case,this will lead to a a build up of dust.
You want to be pushing more air in to the case than you are pulling out to create positive pressure.
Simplest solution is prob swap the SP120's round with the front two intake fans.Default zalman fans are weak sauce,so this would prob create positive pressure.
edit: Did you get an AIO in the end?
Okay, i shall do that. I can tell just from putting my hand over that the sp120 are throwing out so much. Thanks. I want to put SP120's in all round as they are pretty.
I didn't no, I have decided to wait and go for the full WC loop when In a couple of months, I need to save some money for my holiday.
