Hi everyone,
Many of you may have seen my build in the general section, but I am stuck on the cooling, I have chosen a case, the BitFenix Merc Alpha, and I have about £25 to spend on fans (on a budget).
Now, it comes with 1x120mm rear fan which I guess is exhaust. It also has space for 6 more, 2x120mm at the front, 2x120mm at the top and 2x120mm at the side.
My question is... should I get 6 fans so I have maximum airflow? I am not too sure how many or where to put them to be honest. Also, I would like to get LED fans, so the case has an awesome glow
Thanks,
Cam
Thanks,
Cam
