Fan Position
9 Nov 2019
Hi OCUK,
I got some LL120 RGB fans recently and fitted them to my Corsair Carbide 275R case.
I’m probably being OTT but I don’t like the way the intake fans sit as you can only see the back and would prefer to see the front as looks better.
is there any other way I can position these so it looks better?
Pics below
https://ibb.co/qBYz7qf
https://ibb.co/1rwpjcF
thanks
Not if you want good airflow. The case fans should be setup so there is more air going in than out. Keeps the dust down & temps lower.
That is the way, if you reverse the front fans, you're going to have to reverse your cpu cooler and the rear fan. Alternatively put the fans on the roof, or move your case infront of you so you can't see the rear of them
