- 22 Mar 2009
- Cornwall
hi, ordered a the Coolmaster HAF 912 Plus and the Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler. will be turning up tomorrow, so want to be prepared so its a job that i only have to do once. basically, how should i setup the fans?
if i say let the 200mm front fan pull air in, the rear 120mm fan push out. then add say 2 120mm top fans pushing out and also 1 side fan pulling in. that should concentrate all the cold air onto the gfx card and cpu? so which way would i want the cpu fan blowing?
so they will get in the way?
