Hi,
I've just ordered a 980ti to replace my 680's. Thought I'd also replace my h100i fans with noctua's as there a bit noisey and that my case is now going to be put under my desk. I have the front fan pulling in air. The rear and h100i are exhausting are with the fans being at the bottom of the h100i. Is this optimal or should I maybe switch the back fan to also pull in air, so the top is exhausting it all ?
Also, should the h100i fans be below of above the radiator ?
Thanks
Thanks
