Ok this is my current rig and would like a bit of advice where to position my fans please!
This is the Deep Silence 1 case with positions as follows:
2 x 120mm at the front
1 x 120/140mm in side panel
1 x 120/140mm at the rear (where CPU Rad is now)
2 x 120/140 at the top with chimney roof.
I also have a bitfenix recon fan controller so I will most likely wire that in and place temperature sensors round the case (advice on that too please
