- 7 Aug 2012
Hi there, I am looking to put my 3 radiator fans on a single channel of my fan controller. The controller has a maximum of 10w per channel.
I am trying to calculate the wattage of the 3 fans and require a little help. Obviously I know to calculate the power it is current multiplied by voltage, but which current do I use?
The fans are Gentle Typhoons (1850rpm) and according to the documentation:
Rated Voltage: 12V
Operational Voltage Range: 5.0~13.2V
Rated Current: 0.083A
Starting Current: 0.360A
I am worried that the starting current for the 3 fans would draw to much power from the single channel. Nearly 13 watts by my calculation. Would this be a correct assumption, and mean 3 on the single 10W channel is not possible?
I can obviously put them on different channels, but wanted the rad fans all on single channel for ease of adjusting etc.
Rated Voltage: 12V
