Fan profiles for Nvidia
12 Apr 2007
Hi all,
What are people using for this? is there an app that will let me have better control over fanspeed/temp that would be permenant, so I just set it up and forget about it - on an an Nividia card, 200 series?
Thanks.
Don't know about fully automated, but I use RivaTuner, set up some fan profiles and OC profiles then create launcher entries for them. The RT launcher will sit in your toolbar and you just right click on it then select whichever profile you want. Once it's setup it'a only a click or two to change between them. Nice, simple and effective IMO!
Thanks for that, will give rivatuner a try, have ony used Ntune before, which is not that great.
Cheers!
RivaTuner is sooo much better. Uninstall Ntune completely, it's pap! If you look at the guides on guru3d then that will tell you how to set it all up.
