Fan question.
19 Jan 2008
Sunny Wales.
I have recently acquired a White 120mm Sharkoon (Not sure what speed) fan that i would like to use in my PSU but problem is it wont start up spinning when psu starts. If i give it a little nudge it will be it dont seem theres enough voltage for it to start. Any ways round this so it does? Other than that i may just spray a lian or yate white instead if i cant.
Brad.
Sounds like there isn't enough juice being supplied to get it kick-started... Are you trying to run it off a header, fan controller or molex?
Not enough juice.
If being run from a header in the PSU then you have no control and you will either
A) Have to spray the original white.
B) Run it from a header outside the PSU. Either a molex, fan controller or mobo header.
