fan ramps but never drops
Permabanned
30 Dec 2021
Yorkshire
The inside of that psu is very cramped and has a pair of tiny heatsinks so with a 92mm fan it's going to heat up pretty quickly. I read a review on Anandtech and they recorded 1.2 degrees C on the secondary heatsink while hotbox testing. basically the heat generated overpowered the fan and once maxxed out at 3000 rpm it couldn't control the heat and it just kept rising. I suppose the best you can do is ensure it get's as much unrestricted cool air as it needs to suck in. The review said that the fan doesn't even kick in until 60 degrees C so it shouldn't be coming on when the system is idling. Maybe there is a fault with the fan controller in the psu.
But in there cool testing at 25c the psu is fine, my room is around 22c and my case O11 mini as the psu in a separate part of the case so the cpu/gpu shouldn’t be affecting it too much.
I removed the filter that’s next to the psu f or better air flow. I will see how I get on
let not forget when the psu run away it was tested in a room at 45c but the temp went up to 47c and the psu was run at max watts/amps. My problem is in a room at 22c ish and idle power draw
