Hi,
I have an NZXT Phantom full tower case, I'm after some new fans. Now ideally I would like something max 19db (I want the pc to be quieter) with as high air flow as possible. The case has a fan controller so I can change the fan speed manually.
4x120mm (Two of these will be on an antec kuhler 620 single rad so they must have high static pressure.)
3x200mm (One of these will be on the side panel)
1x140mm
I've been looking at the following:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-104-TR
http://www.overclockers.co.uk/showproduct.php?prodid=FG-015-CS&groupid=701&catid=2331
http://www.overclockers.co.uk/showproduct.php?prodid=FG-002-BX&groupid=701&catid=2331&subcat=2335
Cooler+Master+Blade+Master+120+PWM+Fan+120mm+-+4+Pin for £4
Good/bad choices? Is there better?
1x140mm
