I need to replace a fan in my Shuttle as one is getting noisey. However when I look at the installation, the two back fans (one of them needs replacing) are connected to a single 4 pin header. One fan has all4 wires attached and the other 3 (3 pin one needs replacing). I'm still a tad unsure what the additional pin does on the fan header? And I can't seem to find a 60mmx15xx fan with 4 pin connection on! So the plan I guess is to buy a 3pin fan and splice it onto the current wires/connection.
