i have purchased a fan filter for my side fan.
The way it goes on how ever means i need some longer screws
what is the length and M size for the screws on normal fans
Fan screws are not M sized. They are a special type of Self Tapping Screw that screws into the fan cutting its own thread. You could use Metric screws and bolt through though!
