Fan Screws
23 Nov 2010
Cambs
Hi All,
I seem to have a little problem, I brought some NZXT fans for the side & front panel. I went to fit these and the only screws that came in the boxes were 10mm ones. I need to have ones that go through the whole fan (think this would be about 27mmm ones).
Does anyone know where to get these as i'm not sure where to get these or what sizes they need to be.
Thanks
I thought of that but i thought it might be easier so source them locally (so to speak). do you know what size they are? you wouldn't believe me but went to a purple retailer this afternoon as i was passing and they advised me to go to B&Q to get some screws!!
well what worked for me is some 30A fuse wire and the metal bit from a treasury tag, twist it really tight and superglue the fuse wire and when you want to take it out use a pair of scissors and snip the fuse wire, don't really need the superglue but just an idea:)
Sounds intresting, would this cause excessive vibrations? could jimmy something up myself but wat to do it right if you know what i mean
