Ryzen 7950X3D
ASRock X670E Steel Legend
Radeon 7900XTX
64GiB DDR5
NZXT Kraken X63 280mm AIO
980 Pro 1TB NVMe SSD
870 QVO 2TB SATA SSD
BeQuiet Dark Power PSU
Vertical GPU mount
Current fan setup
120mm exhaust
2x140mm pulling on the front mounted AIO
140mm intake below GPU
The fans in this are just what came with the case, put where I could easily fit them.
I do have some more 140mm fans and was going to put two 140mm fans pulling air in at the bottom but the hoses from the AIO are in the way, so I think it'd need to be dual 120mm there.
I've not built a system with an AIO before and am just looking for reassurance that I've got the airflow as best I can. This case has an option to bring air in from the right side of the case, but I don't think it's needed.
Temperatures seem fine when underload, but I've not ran it hard for long yet. The intake fans underneath look a bit.. naff as it's the 'back' of the fan - I don't really need to see the voltage/current specs. Could put a sticker on it?
