Fan Set Up
26 Feb 2012
Hi all,
I wonder if someone could give me some educated advice on the fan set up.
I am waiting for all the components for my new build and I wonder how to set it up the best.
I am getting a Corsair 750D so it will have 2 front fans and 1 back fan. I am also getting a cpu liquid cooler with 2 fans and radiator that will go on top. AMD Fury X with its own fan also that I am not sure where to put. I have seen set ups with the fan on front panel and also with it at the back.
How would you suggest to set it up to achieve good airflow in the case?
Or any advice is appreciated :D
Thx,
Tom
Thank dude,
How should the CPU cooler fans be set up - intake or outflow?
How should the GPU fan be set up - intake or outflow? front or back?
Thx,
Tom
