Hi all,
In the BIOS setting for the Gigabyte AORUS ULTRA…
What are the “Fan Control Use Temperature Input” and the options are:
System 1
System 2
PCIEX16
PCIEX8
EC_TEMP1
EC_TEMP2
VRM MPS
CPU (this is the CPU so that’s easy)
As I need to set the FANs to one of these.
Fans on the m/b or BIOS are assigned (see image):
CPU_FAN = CPU : AIO
CPU_OPT ??? (what is is one for and can I use it for say another 80mm exhaust fan?)
SYS_FAN1 = 80mm exhaust (E1)
SYS_FAN2 = 120mm intake (S2)
SYS_FAN4 = 120mm intake (B2)
SYS_FAN5_PUMP = 120mm intake (S1)
SYS_FAN6_PUMP = 120mm intake (B1)
So I’d like to know what “Fan Control Use Temperature Input” to set each fan to and if they should be AUTO or PWM and also FAN Speed is Auto or Normal…etc.
I just want to check that my Fans are setup correctly… as I don’t think they are because if I open say Google Chrome one or two of the Fans goes much faster and noisier.
Case: Lian-Li PC-O11 Dynamic
Mobo:
Gigabyte X570 AORUS ULTRA (AMD AM4) rev 1 (BIOS vF4h & AMD Chipset vv1.07.29)
FANS:
4x Noctua NF-A12x25 (120mm)
1x Noctua NF-A8 (80mm)
All PWM FANS (4 pins)
CPU Cooler: Kraken x72
The AIO is at the top of the case (exhaust).
The two side fans are intake
The two bottom fans are also intake
I’ve added a 80mm fan to the back of the case acting as an exhaust.
Thanks In Advance ... and sorry for the long message.
System 1
System 2
PCIEX16
PCIEX8
EC_TEMP1
EC_TEMP2
VRM MPS
CPU_FAN = CPU : AIO
Mobo:
FANS:
